Thread: Broken Dimension Commands
    2008-02
    13
    Exclamation Broken Dimension Commands
    I have no clue what happened. I did my weekly reboot for the auto updates, and in the morning all my commands for Dimensions were Broken.. and I can't see How. In CUI they are all there and in propper order (as best as I can tell). But when I go to use them CAD tells me
    _dimlinear Unknown command "DIMLINEAR". Press F1 for help.
    And as per my usual, the help menu was helpless. Any help or suggestions would be greatly appricated. As per any one who is a Cad Opperator, Dimensions are Vital to my job. My next option, is to reload AutoCAD, but I would rather not if I don't have to, I jsut got it set up the way I like it.
    Thanks to any and all advice.
    JEMann
    2007-04
    81
    Default Re: Broken Dimension Commands
    It sounds like you have corrupted one or more DLL's, you may want to do a repair or a complete install. I do not seeing this happen that often but it does happen. Your updates, did they update Internet Explorer to 8? If so i would probably go back to 7
    Patrick K Johnson
    http:\\www.cadenhancement.com
    100 Club sandeep_koodal's Avatar
    2007-10
    God's Own Country
    183
    Quote Originally Posted by JEMann21 View Post
    JEMann
    U have problem with only command: DIMLINEAR?
    try to use comand transparently. Add a period(.) before the command.
    eg: .DIMLINEAR
  1. Replies: 6
    Last Post: 2011-04-25, 07:55 PM
  2. Within IDW, Detail View, Create Broken Dimension
    Last Post: 2010-06-22, 12:54 PM
  3. Bug: Dimension overrides in broken views
    Last Post: 2008-06-09, 02:10 PM
  4. Redefine dimension commands?
    By Mike_R in forum AutoLISP
    Last Post: 2007-08-07, 01:34 AM
  5. Hot Key Commands Vs Selecting Toolbar Commands.
    By matthew.113087 in forum AutoCAD General
    Last Post: 2007-06-28, 11:37 AM
