Thread: New Default Profile
    2008-10
    279
    Default New Default Profile
    Hi all,
    Is there any way to save a different Profile as the default on start up?
    For some reason 'AutoCAD' is the default profile, and I need to change it to 'AutoCAD Architecture (UK)' - this works fine per project by using Options > Profiles.
    But I'd like to be able to save the setting for all new projects.
    Any help much appreciated : )
    2003-10
    San Francisco CA
    1,190
    Default Re: New Default Profile
    Quote Originally Posted by jayc View Post
    Hi all,
    Hi jayc,
    I've got a couple of suggestions/solutions:
    If you are using a desktop icon to open ACA check the target (right-click properties) to see what profile is being used. I use AMEP so my path will be slightly different but it should look something like this:
    "C:\Program Files\AutoCAD MEP 2008\acad.exe" /ld "C:\Program Files\AutoCAD MEP 2008\AecBase.dbx" /p "Guam-AMEP"
    Two things to note here:
    1. The text after the /p character is the profile to be used on open (In my case "Guam-AMEP")
    2. If your system is opening as AutoCAD the AecBase.dbx is probably not being loaded and will have to be added.
    If you are opening ACA via the Start - Programs method you should be able to open ACA go to FORMAT - Options - Profiles and make current the profile you prefer. Then close ACA and it should open with the correct profile.
    Hope this helps,
    Scott Telthorst
    Quality Control Manager
    Helix Electric, Inc.
    www.helixelectric.com
    2008-10
    279
    Nice
    Thanks stelthorst, the right click > properties method worked nicely.
  1. How to set default .arg profile at startup!
    By Cosmic Traveller in forum AutoCAD General
    Last Post: 2009-06-14, 09:30 PM
  2. How to Set your Profile.arg to default!
    By Cosmic Traveller in forum AutoCAD Mechanical - General
    Last Post: 2005-12-13, 07:45 PM
  3. ADT as CAD 2006 Default Profile
    By psukphisit in forum AutoCAD Customization
    Last Post: 2005-09-20, 01:54 PM
