Thread: Sending Commands to Command Line From Modal Form
    Lightbulb Sending Commands to Command Line From Modal Form
    Hi everyone,
    If you have ever tried to create a modal form and then send commands to the autocad command line and not succeeded, this is the way to do it:
    Form myform=new Form();
    Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(myform);
    //After the last line is executed the autocad command line is disabled, until
    //the form is closed. The way to keep the form open and still invoke commands is:
    Editor current=Autodesk.AutoCAD.ApplicationServices
    .Application.DocumentManager.MdiActiveDocument.Editor;
    EditorUserInteraction interaction=current.StartUserInteraction(myform);
    //after the last command is executed the form is hidden and
    //commands can be send to the command line
    //send commands MdiActiveDocument.SendStringToExecute(params)
    //when you are done
    interaction.End();//that restores your modal form, and the command line is blocked again
    I really wish I had figured this one out long time ago. It would have saved me a lot of wasted time. Hoping someone else would find this useful.
    P.S. This code is valid for AutoCAD 2009. I am not sure if it applies for older versions of AutoCAD.
    2000-01
    Seattle WA USA
    5,859
    Smile Re: Sending Commands to Command Line From Modal Form
    Thanks for posting this. I'm sure others will find it useful.
    R. Robert Bell
    Design Technology Manager
    Stantec
  1. Non-Modal Form dissapearing
    By B_Roche in forum VBA/COM Interop
    Last Post: 2009-08-28, 05:16 PM
  2. command line commands
    By dawn-jones164 in forum AutoCAD Map 3D - Data Connect (FDO)
    Last Post: 2009-05-14, 03:07 PM
  3. Repeat command line commands
    By Tim K in forum AutoCAD Customization
    Last Post: 2008-01-04, 12:45 PM
  4. Command Line Feedback on obsolete commands
    Last Post: 2006-07-05, 05:06 PM
  5. show user form from a command line argument
    By lambertm in forum VBA/COM Interop
    Last Post: 2004-11-30, 09:36 PM
