Thread: Plot a metric file in 1/2" scale
    2009-07
    4
    Default Plot a metric file in 1/2" scale
    I have a drawing that was drafted in metric with both metric and imperial dimensions that I want to plot in 1/2" scale. I know 1:25 is roughly 1/2" scale but is there a way I can plot in true 1/2" scale without converting the model space to standard? I'm using AutoCAD LT 2008.
    Last edited by WDS; 2009-08-24 at 03:19 PM. Reason: correcting my lazy unit terminology
    2000-01
    Seattle WA USA
    5,859
    Default Re: Plot a metric file in 1/2" scale
    I'm not sure you are describing things clearly enough.
    Is the "1/2" scale" you are referring to really the 1/2" = 1'-0" scale? Or are you referring to a half-size plot?
    I presume you are referring to 1/2" = 1'-0". (BTW, it isn't referred to as a "standard" scale, it is an "Imperial" scale.)
    If so, you ought to be able to get the desired scaled plot using 125 mm:120 units in the plot scale area of the plot dialog. This assumes the layout was set up as a 1 mm:1 unit plot scale with a viewport at 1:25.
    R. Robert Bell
    Design Technology Manager
    Stantec
    2004-07
    Sydney, Australia
    73
    This might be a little more complicated than it first appears and a little more information would help.
    1 Are you plotting from model or paper space?
    2 Is the object drawn full size in model space?
    3 If you are plotting from paper space what is the scale factor of the viewport?
    If you are plotting from model space and the object is drawn full size use a plot scale of 1:24 leaving the units in the plot dialogue box as mm, or 1:609.6 with the units set to inches (25.4x24).
    Assuming you are plotting from paper space and the viewport scale is 1:20 leaving the units as mm plot with a scale of 1:0.83333333 (20/24)
    This magic number of 24 cones from the number of 1/2 inches in one foot"
    Hope that this is of some help
    Don Smith
    2009-07
    4
    Update:
    Thank you for your response. Sorry I didn't update sooner, I guess a new baby will do that to you. I came up with a solution shortly after I posted.
    The original file was drafted in model space in MM and I wanted to plot in Paper space at 1/2"=1' Scale.
    Solution:
    I created a custom VP Scale using .5 paper unit = 304.8 drawing units. (304.8 being the number of MM in 12"). I don't know if this is the best solution or if another way would work but it got the job done.
  1. Metric Scale & Plot
    By rhayes.99001 in forum ACA General
    Last Post: 2008-01-07, 05:01 PM
  2. Using fields/diesel inside a block for "plot scale"
    By Kirkbride in forum AutoCAD Fields
    Last Post: 2007-03-05, 07:57 AM
  3. "Cannot append to plot stamp log file" ?
    By alexmirb in forum AutoCAD Plotting
    Last Post: 2007-01-26, 01:03 AM
  4. Replies: 4
    Last Post: 2006-02-14, 09:52 AM
  5. "Plot to File" check box not saved to layout ...
    By rclayton in forum AutoCAD General
    Last Post: 2005-05-18, 02:36 PM
