Well, we did it. We finally found Revit's limit, that being a 200MB project file. We have had considerably slower performance and increased instability (out of memory errors, etc.) since the project has begin hovering around this area. In addition, we have been working on this 200MB project across our WAN (w/ Riverbed), so that has led to a lot of increased frustration for our remote users. For one of our users, Revit has become the "killer of architecture."
So, after doing some research and discovering that 200MB is the approx. ceiling for Revit on a 32-bit OS, we decided to do a test run on a 64-bit system. So, we installed XP-64, 12 GB of RAM, and Revit 64-bit on one of our machines and prepared ourselves to be blown away. Not so much. After running some basic tests simultaneously on both my 64-bit machine and my neighbor's 32-bit machine, the machines performed almost identically. Obviously, this is not what we were hoping for.
Now, I have read some posts that talk about how Revit smokes on 64-bit, which makes me wonder if there is some other hardware barrier, setting, or software switch that may be holding 64-bit from bursting forth in all it's glory. This is where I humbly ask for your knowledge and assistance. For those of you noticing increased performance on 64-bit, what are the specs on your systems? In what areas have you noticed an increase in performance? Are there any settings or switches (I'm thinking 3GB switch in XP) that need to be activated?
As always, any help is much appreciated.
