Results 1 to 8 of 8
Thread: Old Link Still Showing UP
    2009-01
    196
    Default Old Link Still Showing UP
    I updated our Arch link but the old link still has parts showing up?? Any suggestions.
    I over write the existing link with the new one. I purge unused and yet Im still getting some things from the old link.
    Thanks
    2005-08
    11,000 feet atop a chute
    1,001
    Default Re: Old Link Still Showing UP
    have the items that are still showing up been copy monitored?
    Otherwise that doesn't make sense.
    2009-01
    196
    All the walls and floors have been set to "Do not copy this type".
    2002-06
    North Central CT
    1,108
    Click on FILE > MANAGE LINKS
    What's showing up in there? Do you have multiple links (with slightly different names)? Maybe that's the issue?
    Just thinking out loud.
    2009-01
    196
    One link is shown under Manage Links.
    2002-06
    North Central CT
    1,108
    Quote Originally Posted by wags5116 View Post
    What kind of "parts" are still showing up?
    2009-01
    196
    Here is my procedure for updating a model.
    (Only levels have been copied)
    1. Open new model from arch, detach from central and audit. Purge Unused.
    2. Over write the existing arch central model.
    3. Open mep model. Pin and select room bounding.
    Theoretically, this should be ready to work on with no issues. However, my spaces don't update. Some walls appear or remain that should not be there. Its quite aggravating.
    2009-01
    196
    Ok, here is some info. that I figured out. The architect has created a room (space in MEP) and the outline of the room correlates to the partial walls that are mysteriously showing up. However, they aren't showing up on the architects floor plans because they are only room boundary lines. Does this make sense to anyone?? Is the only way to fix this issue to go into the arch. model and fix it?
    The space tags are not updating when the link is updated.
    Revit is awesome isn't it??
  1. 2013: Pls Help!!! Pls...Link Dimension not showing up..
    By limruian in forum Revit Architecture - General
    Last Post: 2014-03-19, 04:10 AM
  2. Reflected Ceiling Plan not showing revit link elements
    By barbara.ivo557941 in forum Revit Architecture - General
    Last Post: 2011-10-13, 03:30 PM
  3. Mechanical link not showing in Arch'l Views
    By kwilson.216547 in forum Revit Architecture - General
    Last Post: 2010-06-16, 12:30 AM
  4. Replies: 3
    Last Post: 2009-10-20, 12:28 AM
  5. Walls not showing when copy/monitored from link
    By wdm in forum Revit Structure - General
    Last Post: 2008-10-31, 05:40 PM
