Results 1 to 9 of 9
Thread: Combined Lighting & Power plans & overlapping circuit/equipment
    2009-02
    79
    Default Combined Lighting & Power plans & overlapping circuit/equipment
    So at my firm we'll almost always do combined power & lighting plans on garage levels (and some other areas). Which is all fine and dandy until i started to do some circuiting and saw issues etween conduit runs, busway runs, etc and my lighting circuiting where they intersected. Obviously the circuiting isn't breaking because it will only break w/ other wiring. So then i guess i just have to use detail lines for circuiting purposes? Unless i'm missing something.
    Thanks so much,
    p.s. these forums have been a life saver as we work on our first job
    2009-02
    79
    Default Re: Combined Lighting & Power plans & overlapping circuit/equipment
    as a follow up i saw this scenario which in my opinon is even worse to deal with. So i have some conduits (which i drew as circular mechanical duct) that cross over where i have a fire alarm strobe. The conduits completely obstrcut the view of the strobe. Is the only solution to create some sort of masking region in the strobe family that can be turned on/off?
    2005-08
    11,000 feet atop a chute
    1,001
    When you say "completely obstruct the view of the strobe", are you talking about being hidden under the conduit. If this is the case than your hidden line gap may be too big.
    2009-02
    79
    Yeah that's what i'm saying, here's a picture of what i was trying to say. I'm not really familar with this "hidden line gap" variable that you speak of.
    2005-08
    1,001
    I see the problem. I was assuming it was something else. The detail lines that represent the fire strobe will not show hidden. Even if your view is hidden the conduit will chop up that strobe in fine view. This is the problem with trying to represent actuallity with readable "Schematic in nature" Drawings. I would just move the strobe out from under the conduit. You could make the F opaque instead of transparent. This could interfere with the circle it's in though.
    2009-02
    79
    Yeah there definitley is that problem of REVIT trying to show everything "technically correct" and you have to fight workarounds to get readable drawings. Thanks for the help. I might try your idea w/ the text... I am also going to look at making a masking area for the annotation.. we'll see how that turns out. I'll post again with what i find.
  1. Replies: 3
    Last Post: 2014-11-17, 05:09 PM
  2. GS33-3: Harnessing the Combined Power of GIS and CAD
    By Autodesk University in forum Geospatial
    Last Post: 2013-04-17, 04:41 AM
  3. Overlapping Areas? Different Area Plans still subtract.
    By 3dway in forum Revit Architecture - General
    Last Post: 2008-11-20, 02:49 AM
  4. How to circuit mechanical equipment
    By ahtkelly in forum Revit MEP - General
    Last Post: 2008-01-29, 01:31 PM
  5. Combined Elect Power & Lighting Plan
    By pwmsmith in forum Revit Architecture - General
    Last Post: 2006-03-21, 03:40 PM
