Thread: Mtext Attributes
    2009-08
    3
    Default Mtext Attributes
    Is there any way to create an attribute with Mtext? I need this so that when i mirror a block with two lines of text (the text is rotated so that the sentence is vertical) the text on top does not end up on bottom.
    Turlock, CA
    6,412
    Default Re: Mtext Attributes
    From the help file:
    In the Attribute Definition dialog box, under Mode, select Multiple Lines.
    C:> ED WORKING....
    LinkedIn
    2009-08
    3
    ****..i am using an earlier version that doesn't have this yet. gotta convince the boss man to upgrade.
    2007-10
    Orlando, FL
    118
    Try looking into dynamic blocks?
    2006-02
    424
    What version of CAD are you using?
  1. Mtext In Attributes
    By CADdancer in forum AutoCAD General
    Last Post: 2019-06-24, 08:42 PM
  2. Replies: 1
    Last Post: 2009-05-06, 06:40 PM
  3. Add attributes or dynamic lookups to MTEXT
    Last Post: 2007-06-23, 12:14 PM
  4. Replies: 21
    Last Post: 2007-03-20, 02:03 PM
  5. Replies: 3
    Last Post: 2006-10-31, 05:46 PM
