I am wondering how I can get a linked floor plan from ACA (AutoCAD Architecture) to show up correctly in my Revit Structure project. I've set "Proxygraphics" to 1 in AutoCAD and this has solved some problems, but the linked floor plan (which was built in 3D in ACA) shows up in Revit without doors and walls showing properly. The door swings are not showing, and the walls aren't cut at the doors. It's not a big deal - as an underlay plan I may want just the wall lines showing up w/o doors in the final plan, but I would like the flexibility to show it either way if possible. Is there some kind of object enabler to bring a ACA model into Revit properly? Thanks.
Steve Blackburn
Frost Engineering and Consulting
