Edited on 08.07.09: So I figured it out...you can jump down to the next post if you've run into the same issue and need to see how to do it.
___________________________________
I've been experimenting with Data Extraction from a block into an AC Table all within a single drawing. I've created a Window Tag Block [with a list of attributes in it] and want to transfer the attribute info into an AC Table to create a Window Schedule.
All is working fine. I get to the point where I'm prompted to SORT COLUMNS during the Data Extraction & Table Insertion process and so I sort the Column Headers as I want to see them in the Table -i.e. from left to right -- but the sorting does not show up correctly in the preview of the Table or when I finish all the steps and place the Table in the drawing.
As I created the Window Tag Block w/ the attributes I selected each attribute in the order I wanted them listed in the Enhanced Attribute Editor and ultimately as I wanted to see them in the final Window Schedule Table once i extacted the data to the table.
The created table 'headers' however read from left to right in alphabetical order and do not matching the SORT COLUMN order I set up.
SO, how do I control the Header sequence from left to right so the Table [Window Schedule] reads as it should??
the two attached image should help!
Thanks. d.
