Thread: ObjectDBX issue
    Atlanta, GA
    48
    Default ObjectDBX issue
    I've got a program that uses Object DBX that runs pretty solid about 95% of the time...
    That 5% ends up with an automation error and usually a Fatal Error. Not good. The error is:
    Run-time error -2147417848 - The object invoked has disconnected from its clients.
    The only thing I can imagine is that two people hit the same files that the program calls via ObjectDbx.
    Thoughts?
    Matthew
    Turlock, CA
    5,815
    Default Re: ObjectDBX issue
    You havn't provided enough information as to what your code is doing, but you can try this search at msdn.
    C:> ED WORKING....
    2001-04
    32
    I used to run into this when batching drawings using AutoCad too. It usually happens when AutoCad (for some reason unknown to me) has a problem with a drawing and crashes. It used to happen on a regular basis with R14 due to a memory leak. If I remember correctly, we used to have a similar problem with Mechanical Arx too.
    The error indicates that the server object, in your case objectdbx has stopped running or crashed and as a result, you are disconnected from the process.
    Have your error trapping report the last drawing opened so you can investigate why.
    Not much help, but that's all I have.
  1. OBJECTDBX and VB
    By raj_thapar2003 in forum VBA/COM Interop
    Last Post: 2018-02-15, 01:36 PM
  2. BlockReferences with C# and objectDBX
    By ivan.markov in forum Dot Net API
    Last Post: 2007-06-19, 05:59 PM
  3. C# and ObjectDBX?
    By KevinBarnett in forum Dot Net API
    Last Post: 2006-09-19, 06:09 AM
  4. ObjectDBX issue... I think.
    By mjsregister in forum VBA/COM Interop
    Last Post: 2004-09-01, 08:38 PM
