Thread: Suspended Ceiling Tile
    2004-01
    28
    Default Suspended Ceiling Tile
    Hello,
    I am using Max Design 2010. On almost every project I need to create a 2 x 2 suspended ceiling. I have used the tile maps before and made okay looking ceilings but nothing that ever really looked terrific. Can anyone guide me to a good tutorial so I can make something realistic? I have no problems with anything else in the model, just ceilings... Always....
    And they seem so simple too!
    Thanks in advance!
    -Ivan
    2009-07
    4
    Default Re: Suspended Ceiling Tile
    Seems like a pretty easy thing to model too. Much easier than trying to make a complicated tile material. :P
    I personally, (Just thinking off the top of my head) would make a plane for the ceiling, creating my desired ceiling tile pattern using edges, shape merge/boolean the edges to create my ceiling. I'd then chamfer the edges and extrude the tiles and use the edges of the shape to create splines and use sweep/ extrude to create the metal frame.
    Design Visualization Moderator stusic's Avatar
    2004-10
    Denver, Colorado
    1,515
    I would create a plane and use noise to create a diffuse and bump map. Tile this, and *poof!* your ACT material is made. You can use photoshop to create a border which would act as the supports if you like.
    It seems like something that would be very suited to tiling materials since it's tiled in the real world. ..
    Phillip Bradshaw
    Lead Pixel Pusher, Lucid Design Studio
    CAD Detailer, Proctor Productions
    A doctor can bury his mistakes but an architect can only advise his clients to plant vines. - Frank Lloyd Wright
    I could stop if I wanted to loydg's Avatar
    2007-08
    Denver, CO
    334
    Ivan,
    I you are not concerend with geometry allowances, go for a subdivided planar object. The new poly tools in 2010 will lend themselves well to an effort of this type. You can set up a plane to use as a guide. I'd start with a single separation line and then inset each polygon 1" for the frame. Maybe a slight extrude in for the tiles. Create an MSO material for the frame and the accustical tile (maybe lighting too). Tah-dah!
    Glen Loyd
    Parsons Brinckerhoff Project Visualization
    Lead Design Visualization Specialist
    Autodesk Certified Instructor/3ds Max Design 2012 Certified Associate/Professional
    www.pbprojectviz.com
  1. 2012: Suspended Ceiling Hatch
    By bnutkins in forum ACA General
    Last Post: 2014-09-29, 08:33 PM
  2. ceiling tile alignment + I'm having an off day, halp
    By j_starko in forum Revit Architecture - General
    Last Post: 2011-08-11, 11:01 PM
  3. Ceiling Grid/Tile Patterns
    By Brockway in forum Revit Architecture - General
    Last Post: 2007-07-27, 04:07 PM
  4. Dome Ceiling Tile Pattern
    By john.s.algeo in forum Revit Architecture - General
    Last Post: 2006-11-16, 02:18 AM
  5. Acoustcal tile Ceiling????
    By m_r_meza in forum Revit Architecture - General
    Last Post: 2005-07-13, 06:34 AM
