Results 1 to 10 of 15
Thread: Sheet Set w/ a Multi-line Field
    2008-08
    los angeles
    42
    Default Sheet Set w/ a Multi-line Field
    So I want to use my standard TitleBlock and convert the sheet title attributes into a Field so the sheet title will be automated using the Sheet Set Manager. My normal sheet title block has 3 stacked, right justified & aligned text lines for the 'sheet title' to accomadate the variety and range of title descriptions needed.
    How can I make a Field for the sheet title 'default' attibute which is multi-line; and which allows for flexiblity in regards to how text is placed in the title placeholder depending on the number of words in the title?
    For example:
    'Floor Plan' [placed on the title2 spot as shown on the provide image]
    or
    'Section 3.05
    & 3.06' [place on title2 & title3 spots as shown on the provide image]
    etc.
    See attached file for clarification!!
    thanks, daniel
    All AUGI, all the time TerribleTim's Avatar
    2006-03
    Tacoma, Wa
    643
    Default Re: Sheet Set w/ a Multi-line Field
    Place the field in an mtext box, then use the mtext box grips to get it sized the way you want it. This won't give you much control over "hard returns", I think for that you'd have to look into custom properties.
    2000-01
    Seattle WA USA
    5,859
    Don't forget about multiline attributes.
    R. Robert Bell
    Design Technology Manager
    Stantec
    2006-03
    Tacoma, Wa
    643
    Quote Originally Posted by RobertB View Post
    I'm still back about 3 releases so I haven't gotten there yet. Maybe someday. . . when we have a software budget again. . .
    2008-08
    los angeles
    42
    Thanks guys! I think i read somewhere else on the forum that multiline text does present alignement problems when you line break...but maybe if i can format the text to be right aligned and use the return button when i want to move to the next line the text will stack as shown in my attached example....?
    Multiline attributes? I'll have to look into that. Is that something which can be used with the Sheet Set functionality I'm speaking about? d.
    Cairo - no, not Illinois
    5,069
    nope -- until we can force a hard-return that's recognized in a field you will not be able to control the line break locations on your sheet.
    2008-03
    158
    Quote Originally Posted by TeriblTim View Post
    2010
    2009
    2008?
    If you are on 2008, multiline attributes exist.
    2006-03
    Tacoma, Wa
    643
    Quote Originally Posted by ronsarlo View Post
    2010
    2009
    2008?. . .
    One more.
    2008-08
    los angeles
    42
    Thanks Cadtag...that's pretty much what i've discovered.
    Here another Field question I've posted that maybe you have some insight on...
    http://forums.augi.com/showthread.php?t=106070
    Thanks!! d.
    5,069
    2010
    2009
    2008?
    It doesn't matter -- unless you are willing to lose control of where the line breaks happen in your sheet titles. I can't.....
    RAND ROAD
    PLAN AND PROFILE
    STA.1 570+27.00 to STA 1890+23.00
    works,
    RAND ROAD PLAN
    AND PROFILE STA.
    1570+27.00 to STA 1890+23.00
    doesn't
  1. Custom Field - Sheet 1 of 31, Sheet 2 of 31, etc
    By jeepinaround in forum AutoCAD Fields
    Last Post: 2018-06-14, 09:30 PM
  2. Is there a way to format a field for multi-line?
    By dfarris75 in forum AutoCAD Fields
    Last Post: 2017-11-27, 09:33 AM
  3. Linefeed override in multi-line attribute with field
    By JaCAD in forum AutoCAD Fields
    Last Post: 2011-05-23, 11:57 AM
  4. Multi sheet plotting in Sheet set manager
    By tim.ashton in forum AutoCAD Plotting
    Last Post: 2007-01-27, 02:00 PM
  5. Multi line sheet title
    By vservello in forum AutoCAD Sheet Set Manager
    Last Post: 2005-05-26, 08:34 PM
