Thread: 6.1 Conversion to 7.0
    I could stop if I wanted to Doug's Avatar
    2003-10
    Michigan
    467
    Question 6.1 Conversion to 7.0
    I am about to start a new project that the new roof tool Will make life easier. Is there a problem doing the design in 6.1 and converting to 7.0 later or is it better to work with the slowness problem of 7.0?
    Thanks
    Doug
    2003-05
    Northbrook, IL
    879
    Default Re: 6.1 Conversion to 7.0
    Performance in 7.0 has been variable with some people experiencing severe slow downs and some none at all. As such it is difficult to give you a definitive answer since it will depend on how your system works with 7.0. I would save a copy of one of your old 6.1 projects and then open the copy in 7.0 and play around a bit. Then make your decision based on how your system performs.
    Robert Witte
    2003-04
    Scotland
    1,577
    Upgrading the project later shouldnt cause you any major problems. You get the odd thing now and again with maybe sweeps or something, but generally no problems upgrading.
    I will be wating until a couple of weeks after the release of the next build before I upgrade any projects.... It can be a very stressful situation to put yourself in if things start to go a bit wonky with a critical project, I would advise 6.1 until then...
    I could stop if I wanted to jarod.tulanowski's Avatar
    2001-12
    Columbus, Ohio
    313
    I would stay with 6.1 for now, unless you are doing renderings. the rendering quality is much better in 7.0. Of course you can upgrade a copy of your 6.1 project and render it separately.
    2003-10
    Michigan
    467
    Thank guys... I am going to stick with 6.1 for now.. I am having a hugh slow down.
    7.0 Works fine for a while... Have done all the tricks to make it work better
  1. PDF conversion to DXF
    By Mac Demer in forum AutoCAD General
    Last Post: 2010-05-27, 02:53 PM
  2. PLT to PDF Conversion
    By gio_2 in forum Software
    Last Post: 2010-03-10, 07:23 PM
  3. PDF to DXF conversion
    Last Post: 2010-02-05, 11:11 PM
  4. CTB -> STB conversion
    By stu1037 in forum CAD Standards
    Last Post: 2005-03-17, 07:28 PM
