Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: AutoCAD and Windows 7
    0,0,0 The Origin
    8,570
    Default AutoCAD and Windows 7
    I've been experimenting.
    Installing stand-alone versions of vanilla AutoCAD on the latest versions of Windows_7 (the retail versions will be the same) running in Sun VirtualBox on an earlier pre-release version of 64-bit Windows_7.
    No great amount of testing done - just "will it install?", "will it run?" and a little drawing.
    I think it can be assumed that LT versions and verticals will behave the same as the full versions.
    Win version.............Acad version
    Win7-7600-x86...........A2007(32).....A2008(32).....A2009(32+64)
    Install.................yes...........yes (*2)......yes (32)
    Run.....................no............yes...........yes (32)
    Run despite.............yes (*1)......n/a...........n/a
    "known compatibilty problems"
    Win7-7600-x64
    Install.................yes (to x86)..no............yes (64)
    Run.....................no............no............yes (64)
    Run despite.............no............no............n/a
    Run as administrator....no............no............n/a
    (*1) alert message says there are known compatibility problems. The only "fix" suggested is to buy a later version of AutoCAD - ignore this and click the "run software" button. Obviously, this involves a risk.
    (*2) you may see a message that Explorer is running and needs to be closed even though Explorer is NOT running - click the "ignore" button.
    Last edited by jaberwok; 2009-11-21 at 08:49 PM. Reason: Put "charts" in readable form
    2015-12
    Near Charlotte, NC (Clover, SC)
    112
    Default Re: AutoCAD and Windows 7
    lol @ #2... just click ignore, this message means nothing..
    0,0,0 The Origin
    8,570
    A surprise -
    A2005 WILL run on 32-bit Win_7 in XP+SP2 compatibility mode.
    Earth
    9,805
    Whatever won't install or run on Win7, I just install on a VM running XP.
    R.K. McSwain | CAD Panacea |
    2002-07
    Sycamore, IL USA
    72
    How is the performance with this setup? Our IT department is saying the performance of the VM running XP is terrible.
    2000-01
    Seattle WA USA
    5,859
    Quote Originally Posted by hbisco View Post
    I use VMWare on my Win7 64-bit machine to support older apps. The performance is not terrible.
    R. Robert Bell
    Design Technology Manager
    Stantec
    0,0,0 The Origin
    8,570
    I haven't used VMware for a while - can you now get access to your graphics card's full abilities?
    2000-01
    Seattle WA USA
    5,859
    Quote Originally Posted by jaberwok View Post
    DirectX, yes.
    R. Robert Bell
    Stantec
    0,0,0 The Origin
    8,570
    Quote Originally Posted by RobertB View Post
    DirectX, yes.
    Thanks, Robert. I'll remember for next time.
    All AUGI, all the time Liamnacuac's Avatar
    2016-01
    Earth
    508
    I installed acad mep 2011 64 bit on a nice shiny Dell xps 4 core i7 chipped macihine with Windows 7 64 bit OS. When you start acad, and open multiple drawings, it opens multiple sessions and burns up the available resources on the computer. How do I stop it from opening multiple sessions? Is there a switch somewhere?
    P.S. I have SDI set to 0. I installed 2010 64 bit and don't have this problem.
  1. AutoCAD VBA on Windows 7
    By rhutchi1 in forum VBA/COM Interop
    Last Post: 2012-09-17, 04:56 PM
  2. AutoCAD 2002 freezes as Windows is preparing to load AutoCAD
    By lance_lie in forum AutoCAD General
    Last Post: 2006-08-07, 03:41 PM
  3. AutoCAD & Windows XP
    By cad-work67643 in forum AutoCAD Customization
    Last Post: 2004-07-01, 02:43 AM
