Thread: autocad drawings convert to microstation version 7j
    2009-08
    2
    Default autocad drawings convert to microstation version 7j
    good day!!!
    i'm new on this site,
    i have a drawings from autocad, and i'm using autocad 2010, my problem is i have to convert the autocad drwings to microstation 7j, but the problem is the autocad drawings is done in model space and save it to paper space (layout drawings), how can i convert this autocad layout drawings into microstation,
    i hope that anyone in this group will fix this problem, thank you very much, god bless.
    madz
    Earth
    9,780
    Default Re: autocad drawings convert to microstation version 7j
    Are you wanting to save each layout as a separate drawing file? If so, explore the ._EXPORTLAYOUT command.
    R.K. McSwain | CAD Panacea |
    2009-08
    2
    Sir rkmcswain:
    Thanks for your quick reply, re. on my query, is it possible to convert the Autocad drawings that save in paper space (layout drawings), directly to Microstation ver 7, what are the steps and best way to convert it fast, because our end user need to submit the drawings in Microstation dgn format.
    Thank you very much & GOD BLESS.
    Madz
  1. 2014: Convert to microstation v7
    By gregfarz78 in forum AutoCAD General
    Last Post: 2014-10-07, 12:02 PM
  2. convert from microstation pen settings
    By robert.severance292637 in forum CAD Management - General
    Last Post: 2011-12-12, 05:38 PM
  3. Can someone convert these microstation .cel files to dwg
    By GreyHippo in forum CAD Management - General
    Last Post: 2008-10-13, 04:44 PM
  4. AutoCAD 2006 - Convert 3D models to 2D drawings
    By rshank3499 in forum AutoCAD 3D (2006 or below)
    Last Post: 2008-03-10, 10:29 PM
  5. Replies: 9
    Last Post: 2007-05-30, 03:32 AM
