Results 1 to 6 of 6
Thread: DB attribute visibility not working.
    2009-04
    Houston, TX
    204
    Default DB attribute visibility not working.
    I have been sitting here trying to get these 2 attributes to display correctly using visibility. At first I was just modifying an old block and copied the second attribute from the first, but renamed it, and read forum posts and then made both attributes from scratch and they still won't behave right. Attribute #1 (Address) is only supposed to be visible in the Intelligent states, but it shows the whole time. It has a default value, which does change when I use the block, but I read in someones post this shouldn't affect anything. At a loss as to what's wrong now.
    I just tried one thing, attribute #2 (Wireguard) was set to constant, and once the block was inserted in a dwg it didn't have a grip where you could move the attribute around and reposition, but once I unchecked the constant setting and was able to move it again, now it won't behave correctly either, which if I can't move the attributes they are of no use to me, so anyone who knows a possible work around please fill me in. See attached dwg.
    2008-12
    175
    Default Re: DB attribute visibility not working.
    can you save the sample back to 2009 or 2008? If so I may have a chance to take a look at it tomorrow.
    john
    2009-04
    Houston, TX
    204
    Here's the dwg in 2007 format.
    2008-12
    175
    The easiest thing I found was to lock the attribute and then attach a point parameter/move, this keeps the attributes together when one is moved in case something changes in the future arrangement.
    Something weird is happening though when I open the drawing the open in block editor pop-up is displayed. Normally when I save the block with a name and insert into the drawing this does not happen.
    john
    2009-04
    Houston, TX
    204
    With your suggestion I got it working the way I wanted it. I figured having an attribute locked would override any parameter so I didn't try it, guess I should've. As for the block editor pop up upon inserting the block, I'm not sure why you were getting that, when I insert it I don't get that issue happening. Thanks for your input, much appreciated
    2008-12
    175
    It is strange, and happened on three drawings I opened today. Something is not right with Autocad today hopefully it keeps running until the weekend.
    john
  1. 2012: how to tie visibility parameter to attribute?
    By Ning Zhou in forum Dynamic Blocks - Technical
    Last Post: 2018-09-20, 01:30 AM
  2. Move an attribute with visibility states
    By Ed Jobe in forum Dynamic Blocks - Technical
    Last Post: 2011-03-28, 04:03 PM
  3. Toggle attribute visibility through vlisp?
    By M. Kubitza in forum AutoLISP
    Last Post: 2010-09-22, 07:57 PM
  4. Replies: 3
    Last Post: 2006-04-04, 05:46 PM
  5. attribute not working
    By louis.64641 in forum AutoCAD General
    Last Post: 2005-08-16, 05:29 PM
