Thread: plotting survey points
    2004-08
    69
    Default plotting survey points
    I was given a text file with survey points in it and the engineer wants them plotted out.
    example
    Northing Easting Elevation Feature Code
    7a 11345.166 11425.900 6197.541 newat 15
    64589 7273.966 7720.301 6155.519 TOE S
    64590 7276.165 7726.053 6156.003 TOE
    64591 7278.404 7732.367 6155.854 TOE
    64592 7282.004 7740.191 6156.940 TOE
    64593 7283.277 7746.392 6156.823 TOE
    64594 7279.044 7749.138 6156.163 TOE
    Does anyone have ideas on the easiest/fastest way to insert a block at all these points. This is a Very small part of the file.
    0,0,0 The Origin
    8,570
    Default Re: plotting survey points
    Would this help?
    Google "autocad survey points" for more possibilities.
  1. 2015: Importing survey Points-PLEASE HELP!!
    By a_morris90697235 in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2015-04-10, 07:51 PM
  2. 2014: Survey points not showing
    By ltaylor in forum AutoCAD General
    Last Post: 2013-05-24, 06:10 PM
  3. survey points
    By dbutler.144607 in forum AutoCAD Civil 3D - General
    Last Post: 2009-02-05, 04:42 PM
