Thread: Acad 2007: change SN without reinstall?
    2001-12
    1,714
    Default Acad 2007: change SN without reinstall?
    We have a seat of AutoCAD 2007 installed with a Home Use license, and are converting it to a Stand Alone license instead. We have a lot of customization, as well as ArchT 2007 installed, and would rather not have to reinstall everything. My hope is someone knows what files or registry locations store the serial number, so that I can either revise or delete them, then provide the new Stand Alone SN and get an auth code based on that new SN.
    As I understand it newer AutoCAD does this with no problem, it is now a "feature", but I understand that 2007 still made this difficult. But hopefully not impossible?
    Thanks for any advise.
    Gordon
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,483
    Default Re: Acad 2007: change SN without reinstall?
    I don't think it is an option. You could export your profile, reinstall the software, then reimport your profile. That should save most of your customization. Also, moving your customization out of the AutoCAD folders to your custom folders will reduce the chance of your customization files from being removed when uninstalling AutoCAD.
  1. Mtext Issues Acad 2007 to Acad 2009
    By Eddy B in forum AutoCAD General
    Last Post: 2009-02-13, 12:37 PM
  2. Replies: 2
    Last Post: 2007-01-30, 10:51 AM
  3. Backing up for Uninstall/Reinstall of 2007
    By madcadder in forum AutoCAD General
    Last Post: 2006-11-13, 06:55 PM
  4. ACAD 2007 saving down to ACAD 2004 - ARX Error: eDuplicateKey
    By Dicastaddict1 in forum AutoCAD General
    Last Post: 2006-10-26, 03:35 PM
  5. Error 1309 on AutoCAD 2007 reinstall
    By tyrosch in forum AutoCAD General
    Last Post: 2006-10-18, 03:09 PM
