Thread: Cannot install ACAD 2010 on Windows 7 rc 7100
    2009-03
    Default Cannot install ACAD 2010 on Windows 7 rc 7100
    I am not able to install AutoCAD 2010 on my copy of Windows 7 rc build 7100 32-bit. It crashes with an error stating that I must have .net 3.5 installed. Windows 7 comes with .net 3.5 already, it doesn't show in the add/remove but rather in a separate area similar to XP's "add/remove Windows components". I've toggled this, installed .net 3.5 and 3.5 sp1 redistributables.
    From what I gather, AutoCAD 2010 installs fine on Windows 7 64-bit.
    I believe that it won't install because the installer cannot find .net 3.5 among the listed installed apps.
    I am using a network deployment, but have the same results when installing straight off the AutoCAD disk.
    Has anyone else run into this issue? Does anyone know where the installer checks for .net 3.5? i.e. is it a registry key I could create?
    Adam Stecker
    KDF Architecture Inc
    0,0,0 The Origin
    8,570
    Default Re: Cannot install ACAD 2010 on Windows 7 rc 7100
    Get hold of a later copy of Windows_7 - the 7600 RTM version is around and works fine. I cannot actually install A2010 on my 32-bit machine because the processor is not acceptable but the 32-bit version of A2009 (which also uses .net 3.5) installed and seemed to work
    Member esaffle's Avatar
    2007-03
    Madison, MS
    11
    Quote Originally Posted by adam.stecker View Post
    I am not able to install AutoCAD 2010 on my copy of Windows 7 rc build 7100 32-bit. It crashes...
    Adam,
    I installed ACAD 2010 last week in the same format you described, but have only had it crash once. And with that crash it just disappeard. It didn't give me any errors at all. I did, however, install straight from the disk, not through deployment.
    I know this doesn't answer any questions, but it does show that it will work on the 7100 build.
    jaberwok, any ideas on how I can upgrade my 7100 to 7600?? Full reinstall is alright too! And will my existing key from MS still work? Just a side question
    0,0,0 The Origin
    8,570
    Google "Win7 7600", you see that it is available from MS Technet.
  1. 2015: Repairing ACAD 2K LT install
    By ccoulter690810 in forum AutoCAD LT - General
    Last Post: 2015-01-30, 02:36 AM
  2. 2011: ACA 2010 - Install express tools after install
    By shane.249457 in forum ACA General
    Last Post: 2010-07-14, 03:15 PM
  3. WINDOWS 7 INSTALL
    By Doug in forum Revit - Hardware & Operating Systems
    Last Post: 2010-06-02, 02:27 PM
  4. Any Windows Vista x64 Updates NOT to install on a MacBook Pro running Parallels 4.0 and Revit 2010
    By Design Apparatus in forum Revit - Hardware & Operating Systems
    Last Post: 2009-09-11, 08:15 PM
  5. Acad 2009 install
    By vrphillips in forum Hardware
    Last Post: 2008-06-23, 02:47 PM
