I'm a Revit virgin and I'm not entirely familiar to the system-I'm looking for an arched head double door in the libraries but can't find anything.
Any ideas/suggestions?
Thanx
Thanx
You may want to post this in the Revit General or Families forum. You will probably get a faster answer to your question there.
Hi
Please note I've *moved* this thread from the CAD Mgmt. General Forum to this one as I believe it would be better served here.
Note to Revit Moderators - If this is not the correct Revit Sub Forum can I please ask that you move it to the appropriate one.
Thanks, Mike
Forum Moderator
Check www.revitcity.com they have lots of great stuff there! The exchange is not active yet on AUGI. Good luck!
Also, start learning to make your own families as soon as you are into the program further! It is a good challenge. Dig in! Work with the content you can borrow, and then start making some simple modifications to the geometry of the family. Modify some simple things. Look through the tutorials, Tips & Tricks forum, and the families forum. There are lots of tutorials around in these to help you!
