Has anyone had any problems with an Oce TDS 450? We changed our old machine, TDS400 to the TDS450 and now none of our projects print properly. All of our screened and gray lines print extremely light or they are not there at all, this goes for RAC 2009, 2010 and ACA 2006. It's very frustrating and to change the line weights in Revit will be catastrophic! If we send the files out to print we get the same result.
We also have image problems. When we make the DWF file the image appears, then when we print the image is not there, but if we make a PDF file and print the file, it's fine. On occasion when we open the project jpg images disappear or are all blacked out. Has anyone experienced this as well?
We have a KIP 3000 and are having the same problem. We have to plot to PDF then send it to the KIP. I have talked to KIP tech support with no help. This is using Revit 2010 we did not have this problem with 2009.
I have followed this same discussion on Autodesk discussion groups and lots of people are beating there heads against the wall because images are not plotting in Revit 2010.
Whats up Autodesk?
We were able to plot raster images for a while but now cannot now to any plotter, printer, or pdf??? Autodesk really screwed up this version of Revit
I am using Revit 2010 and my trusty HP500 (which has never had issues printing images before). I am trying to plot a client titleblock that contains a jpeg logo. I have tried all the above related suggestions, and all I can find that works is print to PDF, then send the PDF to the HP500. What a pain in the butt!!!!! Anyone have any ideas on this? Any response from AutoDesk?
Karen
I am having the same issues. Ours is a Ricoh 480 Large format. We have the current drivers, and have tested on multiple operating systems. Revit 2009 printed fine, 2010 tried again, no luck. Dropped down the res on the jpegs, no luck. The drivers don't have the smartspool option. PDFs work fine, as well as all of our small format printers straight from revit. Any ideas?
We just got a HP Designjet 4500 HP-GL/2, and we are taking baby steps into 2010. The same issue with us in our titleblock. But for us it is printing the images, but they are upside-down....lol the images do not show up in 2010 print preview. We have families made for our venders with logos in them, and they are printed upside-down also. It must be something with an image inside of a family. We have printed images pasted onto the sheets and it prints fine.
Lovely
We are having the exact same problem with Revit MEP 2010. All our 09 projects plotted raster images just fine. This is on a KIP 5000.
Resizing the image to less than 400 did not work.
This little surprise caused a project to go out late! Nice job Autodesk!
I have the same problem here on an iX4000 canon a3 printer. This in unacceptable.
This happened to me in the initial version and NOW on WU2 it's here again.
The problem is even the pdf's get the same treatment.
