Thread: ACA2008/ ACA2010 Issues: Views Process Slowly
    2007-05
    2
    Question ACA2008/ ACA2010 Issues: Views Process Slowly
    We recently upgraded to ACA2010 from ACA2008. We noticed that projects created in 2008 and opened in 2010 operate slowly and frequently crash. In an attempt to avoid this issue, we took the contents of a 2008 project that was only in its preliminary stages and copied and pasted it into the proper locations within a new 2010 project. While the constructs process fine, the views process very slowly, in particular while saving, auditing and purging (thus far). My suspicion is that the issue lies in the annotative objects (since that is at (this point) the only real difference between the view and the construct). Any ideas?
    2006-12
    Big "D"
    3,711
    Default Re: ACA2008/ ACA2010 Issues: Views Process Slowly
    Quote Originally Posted by sparker View Post
    Welcome to AUGI and congrats on your first post.
    I'd check your template file paths and any other paths for that matter. It sounds like ACA is looking for a path that is no longer there. That would make the files very very slow. On previous releases, the file that was pathed wrong after I uninstalled the older version was the "add a plotter wizard" shortcut. Make sure it's pathed correctly. I dont' have 2010 installed yet but it should be found under program data/acd2010/enu/plotters.
    2007-05
    2
    Arrow Re: ACA2008/ ACA2010 Issues: Views Process Slowly
    Thanks for Responding.
    The template paths appear to be fine. Since my last post the docs have proceeded further and the additional complexities of the drawings have illuminated other issues. I found that whenever I attempted an "Edit Xref in Place" command, I received a message indicating the following:
    _________________________________________________________________________
    "The Xref selected references a previous Release drawing file format. If edits are saved back to the Xref, the referenced drawing file will be updated to the current Release drawing format."
    I receive this message each and every time I attempt the command, no matter how often I edit and save the Xref, whether in the Base itself or using the "Edit in Place" command. In conjunction with that, it takes a very long time to open the files, or update the Xref in addition to the issues previously mentioned (saving, auditing, purging).
    Any other ideas?
    Sam
  1. CM401-2: Skeleton Key: Using A Process Analysis To Unlock Design Issues
    By Autodesk University in forum CAD Management
    Last Post: 2013-05-05, 03:21 AM
  2. Compatbility problem ACA2010/ACA2009
    By giglio.matteo in forum ACA General
    Last Post: 2010-03-12, 12:02 PM
  3. How to use AIA Standard in ACA2010
    By Famaice in forum ACA General
    Last Post: 2009-11-20, 08:21 AM
  4. Whishes for ACA2010
    By Pedro Aroso in forum ACA Wish List
    Last Post: 2008-10-27, 04:10 PM
  5. issues with views
    By timm.156421 in forum Revit MEP - General
    Last Post: 2008-05-08, 07:03 PM
