Thread: Point Cloud (laser scanning) database in NavisWorks
    2008-07
    30
    Default Point Cloud (laser scanning) database in NavisWorks
    Hi All!
    We have a large Cyclone point cloud database from laser scanning (point cloud with RGB data) and want to import it into NavisWorks. What is the best workflow to do that? what export/import file formats should we use?
    Thanks in advance for your help!
    AK
    (I have also posted this on Survey forum, but thought this forum is way more active and posted it here as well!)
    2015-12
    2,095
    Default Re: Point Cloud (laser scanning) database in NavisWorks
    Do you have the PTS file(s)? Those can be read directly with Review or higher. You can even publish it to NWD for those without either viewer software (although IIRC the Cyclone viewer will run in view-only mode, but I think Freedom is a little "lighter").
    2008-07
    30
    Thanks for your reply!
    I'm not sure about that. The company that does the scanning for us just said that they can give us the model in any format supported by Cyclone. I'm not sure what ASCII format they are using themselves.
  1. PD33-1: Plant Design and Laser Scanning: It's Ready for Prime Time!
    By Autodesk University in forum Plant Design
    Last Post: 2013-04-17, 04:22 AM
  2. Replies: 0
    Last Post: 2013-04-10, 01:34 AM
  3. Create an irregular surface from selected point in a point cloud
    Last Post: 2012-03-10, 12:15 PM
  4. Laser scanning survey
    By sont.nguyen in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2011-11-23, 05:14 AM
  5. 3D Laser Scanning - Revit Workflow
    By sfraney in forum Revit Architecture - General
    Last Post: 2010-11-16, 11:19 PM
