Thread: Serious problems between Navisworks 2010 & Revit 2010
    2008-07
    12
    Default Serious problems between Navisworks 2010 & Revit 2010
    I am a seasoned veteran of Navisworks since version 5 long ago and I have come against some serious problems between Revit 2010 (all disciplines) and Navisworks Manage 2010.
    Some of these problems are leftovers from Navisworks 2009.
    #1. This is a problem left over from versions 9. When exporting from Revit Architect 2010 to Navisworks via the Navisworks pluggin, if your project settings are set to millimeters then you expect to have millimeters in Navisworks. I check my objects file units and they are indeed in millimeters but when I scale it the object is about 1000x too small. I checked the settings in the plugin also.
    #2. I'm recreating an animation that I did in version 2009. I have an update to my model and schedule (it worked in 2009) that I have brought into 2010 but I cannot get it to repeat itself. I am trying to animate columns to go from the ground up to the podium and then the rest of the floors. I've tried everything in the book (well there really is no book as everyone is aware of by now) and I can't get it to work. The animation will not connect to the timeliner. I've checked my scripts and my animations and it just isn't happening. I run my animations and they run find. I check my scripts and they are good. I go into timeliner and check my selection set attachment, my script, and it just will not work!!!!
    It's like the timeliner is not recognizing the script at all. The columns blink that shows me something should be happening but nothing does.
    I have a few other things to share but that's it for now. If anyone else is animationg in Navisworks 2010 and using Revit 2010 and are experiencing the same problems or have a solution then please share. It all comes back in the end!
    2009-02
    Brisbane, Australia
    127
    Default Re: Serious problems between Navisworks 2010 & Revit 2010
    Quote Originally Posted by dramage.190144 View Post
    ...The columns blink that shows me something should be happening but nothing does...
    Just some thoughts. I've done some nice animations, but I'm no expert in this and have never had much luck with scripts in 2009.1, and still avoid them in 2010. What I do now is assign my animations to specific tasks covering the timescale needed for the animation. ie if a plane overflys my site it takes about 5 seconds to cross the site, but if the timeliner for the site covers work over hours, days or months then there's no chance of the plane being seen, except maybe a blink, so I assign the animation to a task that covers the timeline needed, select Scale for animation behaviour and leave the script column blank.
    One issue that annoys me is finding a simple way to have the animated object stop in position at the end of the animation.
  1. Revit to Navisworks - No exporter in 2010!?
    By barnold.216936 in forum NavisWorks - General
    Last Post: 2010-01-15, 09:56 PM
  2. Navisworks 2010 Revit 2010 and DWFs
    By jason.combs in forum NavisWorks - General
    Last Post: 2009-09-16, 12:45 PM
  3. Problems with exporting from Revit 2010 to NW 2010
    By anthony.foster-davis in forum NavisWorks - General
    Last Post: 2009-06-12, 04:39 PM
  4. Revit 2010 Doors and Windows are not cutting walls in Navisworks 2010
    By mike.massey in forum NavisWorks - General
    Last Post: 2009-06-05, 07:30 PM
  5. NavisWorks Manage 2010 64 bit Animation Problems
    By gdb in forum NavisWorks - General
    Last Post: 2009-04-30, 10:03 AM
