Thread: MSI Packaging
    2009-08
    3
    Unhappy MSI Packaging
    Im trying to install in multiple pc the Autocad Mechanical 2010 thru (window installer files) acad.msi files and also acadmlp.msi file as the mode of installing the softare rather the conventional way of installing thru setup.exe for which im making an admin image by which it is loading but the language pack is not installing. Both these msi files are connected to each other and many files required are installed by the other msi files. These files are not installing the software perfectly. Can anyone tell me how to install the software properly with the help of windows installer files found inside the admin image. Thanks
    Earth
    9,805
    Default Re: MSI Packaging
    I can't speak for Mech., but with vanilla AutoCAD and LDT, you can install using the .msi files, but you'll miss all the dependencies that need installed also. That is why "setup.exe" is there. I have seen people put together most if not all of the msi files in a batch file and run it this way also.
    R.K. McSwain | CAD Panacea |
    2007-07
    89
    Have you thought about using soming like InstallShield?
    Would allow you to rebuild the MSI or build a true bespoke MSI that matches the install to your requirements.
    2000-01
    Seattle WA USA
    5,859
    Have you read the documentation in the Network Administrator's Guide on GPO installation? Also note there is a posted TS document at www.autodesk.com related to some missing info from that guide.
    R. Robert Bell
    Design Technology Manager
    Stantec
  1. Packaging Files. Is there another way?
    By atlbirds345447 in forum CAD Management - General
    Last Post: 2013-09-12, 05:09 PM
  2. MSI Packaging
    By gregory.melvin in forum AutoCAD LT - General
    Last Post: 2009-09-02, 11:35 AM
  3. Packaging a DVB program
    By Coolmo in forum VBA/COM Interop
    Last Post: 2006-10-10, 04:07 PM
  4. Revit 8 packaging gets face-lift
    By Scott Hopkins in forum Revit Architecture - General
    Last Post: 2005-04-25, 03:20 AM
