Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: How to find BLOCK area
  1. #11
    2003-07
    396
    Default Re: How to find BLOCK area
    The area of a block is two different answers the actual area hard clipped to the objects and the bounding box which is just that a box.
    There is some software available that will draw a pline around an object "shrinkwrap" but the object must be of a closed shape. Another version is available but must be purchased.
    See also www.lee-mac.com convex hull
  2. #12
    2018-07
    2
    'Found here :
    Public Sub FlipTest()
    Dim ssFlip As AcadSelectionSet
    Dim pt1 As Variant
    Dim pt2 As Variant
    ' get selection set from user
    Set ssFlip = ThisDrawing.SelectionSets.Add("flip")
    ssFlip.SelectOnScreen
    ' get bounding box of selection set
    GetSSBoundingBox ssFlip, pt1, pt2
    ' draw a line from point to point
    ThisDrawing.ModelSpace.AddLine pt1, pt2
    ssFlip.Delete
    End Sub
    Public Sub GetSSBoundingBox(ss As AcadSelectionSet, ptMin As Variant, ptMax As Variant)
    Dim entItem As AcadEntity
    Dim ptImin As Variant
    Dim ptImax As Variant
    Const X = 0
    Const Y = 1
    ss(0).GetBoundingBox ptMin, ptMax
    For Each entItem In ss
    entItem.GetBoundingBox ptImin, ptImax
    If ptImin(X) < ptMin(X) Then ptMin(X) = ptImin(X)
    If ptImin(Y) < ptMin(Y) Then ptMin(Y) = ptImin(Y)
    If ptImax(X) > ptMax(X) Then ptMax(X) = ptImax(X)
    If ptImax(Y) > ptMax(Y) Then ptMax(Y) = ptImax(Y)
    Next
    End Sub
  3. #13
    2018-07
    2
    Found here
  1. Find a block in a drawing
    By pangell in forum AutoCAD General
    Last Post: 2016-08-07, 05:43 AM
  2. Find Block by Attribute
    By timharris677625 in forum Dot Net API
    Last Post: 2014-11-29, 07:20 AM
  3. FIND AND REPLACE BLOCK.
    By aijazahmed in forum AutoLISP
    Last Post: 2013-08-05, 04:14 PM
  4. 2013: Can't find user block in block list while creating a multi-leader style
    By rsturgeon502669 in forum AutoCAD Annotation
    Last Post: 2013-07-08, 07:05 AM
  5. Where to find area info in Oracle Spatial
    By aaronch in forum AutoCAD Map 3D - General
    Last Post: 2005-06-10, 05:44 PM
