Thread: Family parameter formulas
    2009-01
    21
    Default Family parameter formulas
    I'm trying to remember the formulas for family parameters and i figure this is the best place for it.
    I've got a sliding pocket door, that i've been asked to make parametric in terms of how much it's slid open in graphics. I have one parameter called "panel width" and i'd like the "open distance" to error or be set to the "panel width" as a maximum. So if the panels are 3' wide and someone puts the "open distance" at 3'6" it would reset to the panel width or just give them an error. i'm fine with either outcome, i just don't want it to accept something bigger then whatever they set as the "panel width"
    thanks ahead of time.
    2006-01
    4,516
    Default Re: Family parameter formulas
    If (open distance>panel width, panel width, open distance)
    That will tell it "If they put in something greater than Panel Width, just use panel width instead. Otherwise use the value they gave you."
    But, i would make the panel symbol in plan USE Panel Width, and then CONSTRAIN it with another dimension. That way when the doors change size, the panels and the panel symbology are the same. (Maybe thats what youre doing?) I suppose in either case you would want the formula for the opening amount...
    All AUGI, all the time Munkholm's Avatar
    2006-09
    The Kingdom of Denmark
    560
    I´ve done something similar once, and used an "Opening Percentage" parameter to control it...
    Opening Width = User Input
    Opening Percentage = User Input (1-100%)
    Opening Drive = (Opening Width / 100) * Opening Percentage
    Hmm... on a second thought... I might need to check that none og the dumba**´es have entered more than 100%
    - Klaus Munkholm
    100 Club RobG's Avatar
    2005-12
    Spokane, WA
    164
    Quote Originally Posted by twiceroadsfool View Post
    I just tried this method myself and it's giving me an error of "there is a circular chain of references among the formulas"
    Rob Grant
    Architectural Technician - Woodworker
    2006-01
    4,516
    Which parameter did you put the formula in?
    There will be:
    Panel Width (user input)
    Opening Width Input (user input)
    Opening Width Actual (if(Opening Width Input>Panel Width, Panel Width, Opening Width Input)
    Ten OWA has to be put as the constraint for the door opening.
    Circ. chain sounds like you used one of the parameters, in the parameter, lol....
  1. 2015: Parameter formulas
    By bharlow1986651702 in forum Revit Architecture - Families
    Last Post: 2015-05-18, 12:17 PM
  2. 2013: Link family parameter formulas to project parameters
    By bhollon in forum Revit MEP - General
    Last Post: 2014-04-25, 05:04 PM
  3. Unique Parameter Formulas per Type?
    By mike.dixon in forum Revit MEP - Families
    Last Post: 2009-12-14, 11:54 PM
  4. Parameter Formulas
    By techsupport.161645 in forum Revit Architecture - Families
    Last Post: 2009-08-27, 07:18 PM
  5. Formulas (Text to Family Parameter)
    By mcox.157847 in forum Revit Architecture - Families
    Last Post: 2009-01-22, 09:16 PM
