Thread: Navisworks Manage 2010 vs. AutoCAD 2008
    2000-01
    Seattle WA USA
    5,859
    Exclamation Navisworks Manage 2010 vs. AutoCAD 2008
    This is a heads-up to the folks here that installing Navisworks Manage 2010 appears to hose AutoCAD 2008's VBA support.
    Once I installed Navisworks my VBA code started returning errors on any layout's Block object. Uninstalling Navisworks restores AutoCAD's VBA support.
    Note that this issue does not occur with AutoCAD 2010. I have an active support case open with Autodesk.
    Symptom in AutoCAD:
    Running the following code in AutoCAD will result in an error once the code gets to For Each aObj statement.
    Sub Test()
      Dim aLayout As AcadLayout
      For Each aLayout In ThisDrawing.Layouts
        Dim aBlock As AcadBlock
        Set aBlock = aLayout.Block
        Debug.Print aBlock.Name & ": " & CStr(aBlock.Count)
        Dim aObj As AcadObject
        For Each aObj In aLayout.Block
          Debug.Print aObj.ObjectName
        Next aObj
      Next aLayout
    End Sub
    R. Robert Bell
    Design Technology Manager
    Stantec
    2000-01
    Seattle WA USA
    5,859
    Exclamation Re: Navisworks Manage 2010 vs. AutoCAD 2008
    This issue has been resolved by Service Pack 1 for Navisworks 2010.
    R. Robert Bell
    Stantec
    2,095
    Default Re: Navisworks Manage 2010 vs. AutoCAD 2008
    Oh joy - that means another program to roll out. Although at this point it might be worth waiting around for the 2011 release...
    If you are going to fly by the seat of your pants, expect friction burns.
    Some say beauty is in the eye of the Beholder... perhaps so, but I've only seen the disintegration beam.
    Everyone else being wrong is not the same thing as being right.
  1. Navisworks Manage 2010 - where my materials gone to?
    By TEF in forum NavisWorks - General
    Last Post: 2010-01-15, 07:24 AM
  2. Navisworks Manage 2010 vs. AutoCAD 2008
    By RobertB in forum AMEP General
    Last Post: 2009-06-23, 10:50 PM
  3. Navisworks Manage 2010 vs. AutoCAD 2008
    By RobertB in forum VBA/COM Interop
  4. navisworks V5 to manage 2010
    By matt.schnoor in forum NavisWorks - General
    Last Post: 2009-05-28, 12:25 PM
  5. NavisWorks Manage 2010 64 bit Animation Problems
    By gdb in forum NavisWorks - General
    Last Post: 2009-04-30, 10:03 AM
