Results 1 to 7 of 7
Thread: Script Help
    Default Script Help
    How can you end a line with out using your mouse?
    LINE
    -100
    DELAY 1000 << I need to know so i can add in a delay. Thx
    LINE
    -100
    -400
    0,0,0 The Origin
    8,570
    Default Re: Script Help
    Hi, welcome to AUGI.
    Insert a blank line -
    line
    -100
    (code)
    line
    John B
    Thankyou.
    2006-04
    (getpoint "Anywhere on the Enter Key =>")
    1,160
    John, I can't see it would work without using mouse.
    The only thing I can see is entering the command by using verbal input.
    And Geoffrey, You learned this from John after two and a half years!
    0,0,0 The Origin
    8,570
    Quote Originally Posted by BoKirra View Post
    It's a script; scripts are about keyboard input.
    The blank line is the same as hitting "enter" or the spacebar.
    Hmm. Yes. Perhaps he put in a REAAAAALLY long delay.
    John B
    2006-04
    1,160
    But Geoffrey has to select the 1st point by using a mouse.
    0,0,0 The Origin
    8,570
    No. The "0" in line 2 does that.
    Yes, it should be "0,0" but (luckily) it works anyway.
    John B
  1. Script
    By robert.josi in forum Deutsch - AutoCAD LT / AutoSketch
    Last Post: 2009-08-07, 07:35 PM
  2. Looking for a script
    By jsteinhauer in forum Revit Architecture - General
    Last Post: 2009-04-22, 07:41 PM
  3. script help
    By mark.momper in forum AutoLISP
    Last Post: 2008-02-22, 07:48 PM
