Ok i have read through a bunch of these threads and can not seem to get an exporter froom revit structure 2010 to navisworks.
Do you need to have a purchased copu of navisworks to have the Revit Exporter?
Please help
thanks
Please help
thanks
Yes. The only way that the Exporter in Revit appears is when Navisworks is installed after Revit is installed.
R. Robert Bell
Design Technology Manager
Stantec
Download the 30 day evaluation of NavisWorks it has the same functionality as the full version.
If not you will need to export to DWG and send that to be inserted in NW
Installed navisworks after revit and still not getting the export option. Can someone provide a copy of the portion of the ini file to manually load. Much appreciated.
ECName13=Navisworks 2010
ECClassName13=NavisWorks7.LcRevitExportCommand
ECAssembly13=C:\Program Files\Common Files\Autodesk Shared\Navisworks\2010\nwexportrevit2010\nwexportrevit2010_7.dll
ECDescription13=File exporter for Navisworks 2010
