Results 1 to 6 of 6
Thread: Annotation, Attribute and scaling
    2008-12
    3
    Question Annotation, Attribute and scaling
    I'm having an issue with a block I'm trying to create. I've got 2 text elements in the block, one singleline text the other will be an attribute. The singleline text is fine, it scale per the annotation scale like it should. Now when I then add the attribute to the block then insert it, the singleline is still kosher, but the attribute is scaled way too big, like 50x the insertion size. When I edited the block and added the attribute it looked fine, the text was at the right size and all. When inserted into a drawing it's just all messed up. Any thoughts on what I may be doing wrong?
    I've attached the block in question...
    -Jason
    2001-05
    Austin, TX USA
    2,201
    Default Re: Annotation, Attribute and scaling
    Try setting the attribute to not be annotative. Annotative text inside a block that is also annotative don't mix very well.
    2008-12
    3
    Quote Originally Posted by Glenndp View Post
    Thanks for the reply. Well the static text is scaling correctly and that's annotative. Do attributes have an issue with scaling correctly?
    Thanks again,
    -Jason
    2001-05
    Austin, TX USA
    2,201
    I've only had issues when the text or attributes were also set to be annotative. When changing them to not be, then they worked just fine.
    2005-12
    Greeley, CO
    116
    is your triangle supposed to remain a fixed size? If the triangle is supposed to scale as well change annotativedwg to 1. Then make the attribute and text non annotative and scale them to correct 1:1 size. This will make everything scale together and correctly.
    2008-12
    3
    Quote Originally Posted by bearden383 View Post
    No the triangle stays at the size it is, we just wanted the text to scale according to drawings scale. I will try your suggestion tho. Thanks for the reply. Boy coming back to autocad after 12yrs of Microstation is an adjustment.
    Thanks again...
  1. Annotation label scaling
    By jhs.222310 in forum Revit Architecture - Families
    Last Post: 2009-07-21, 10:11 AM
  2. Annotation Scaling Performance Hit
    By philA in forum AutoCAD Annotation
    Last Post: 2008-10-13, 10:29 PM
  3. Annotation Scaling
    By Binu Mathew in forum AutoCAD General
    Last Post: 2008-08-26, 02:59 PM
  4. Non-scaling annotation symbol
    By ErichB in forum Revit Architecture - Families
    Last Post: 2007-09-17, 06:37 PM
  5. ACA 2008 & Annotation Scaling
    By .chad in forum ACA General
    Last Post: 2007-04-05, 04:12 PM
