I am working on a project that has wall angles of 147, 90, 57, 33. I can't even begin to tell you how much fun that is. We have constant STC errors. We cannot save to central becuase a fitting is off by .002 degrees. We have find the offending fitting delete it than STC. When we originally draw the fitting everything is fine, but for some reason the duct and branches "jump" in weird angles after the connection is made, causing the offending connections.
What is the best way to lock orthagonal angles of increments as these? I have looked into snap angles and those really dont seem to help.
I was reading in the Architectural post about this concren and one response was.
"If you're dealing with lots of different angles, then I suggest you break your own arms and take sick pay as it's probably more fun"
My problem is, we are so busy, I would have to work with two broken arms.
