Thread: Weld Symbol AutoCAD 2008
    2005-11
    72
    Smile Weld Symbol AutoCAD 2008
    This is my attempt at a weld symbol. It has visibility states broken into several lookup actions accessed through the type of near side weld. I also included an arrow with optional second segment and multi line note. If anyone has a wat to simply toggle the notes, all around, and field weld flag, I would love to learn it.
    This did take hours to create, bu I have eliminated several olde blocks from the library and my designers will follow the standards a little better.
    Clark Johnson
    Enerflex
    10815 Telge Rd.
    Houston, Texas 77095
    2008-12
    175
    Default Re: Weld Symbol AutoCAD 2008
    The field weld and all around symbol can be controlled with the scale function, when off they are scaled 0.0001 of original height.
    john
    2005-11
    72
    John,
    I am controling them with scale, but how do I toggle them. By this I mean I would like to select an icon and change the state without another selection. Is this possible?
    Clark Johnson
    Enerflex
    10815 Telge Rd.
    2008-12
    175
    The one thing missing from your weld symbol for bevel, "V" and square groove welds is the depth of bevel and weld size(effective throat)
    written like this 1/4(3/16) for bevel and effective weld
    or on bevels and fillets (1/4) for the effective throat
    For the part labeled cap weld the arc should be touching the weld symbol line, this way it can easily changed froam a backing weld (empty arc) to melt through (filled arc).
    2005-05
    29
    its great DB
    but how can I scale to use in Decimal measurement
  1. Weld symbol gap
    By matt__w in forum Revit Structure - General
    Last Post: 2010-07-26, 02:02 PM
  2. Help with weld symbol
    By REVIT_MONKEY in forum Revit Structure - Families
    Last Post: 2010-05-06, 09:49 PM
  3. Weld Symbol
    By David van Erk in forum AutoLISP
    Last Post: 2009-10-10, 06:12 PM
  4. Weld Symbol AutoCAD 2008
    By clarkrj in forum Dynamic Blocks - Technical
    Last Post: 2009-09-25, 01:03 PM
  5. Weld Symbol - Bottom Contour Symbol
    By kcooper.190440 in forum Revit Structure - Families
    Last Post: 2008-10-07, 07:21 PM
