OK - to unclutter the layers toolbar drop-down when using xrefs, a lot of people will go into the layer manager dialog box & select "Show all Xref dependent layers" in the named layer filters box at the top, select "invert filter" & "apply to layers toolbar" so that all of the xref'd layers don't have to be scrolled through in the pull-down.
Common, right?
Well, how about making this the default when you open any drawing? I would like to have this as my default instead of having to set it for every drawing every time I get into them. Even when you make the changes, they don't get saved in the drawing so you have to change it every time you get into the same drawing. I figure there is a SYSVAR or a little code somewhere that would have to be in the MNL file to make them be persistent settings, but I can't find it.
Any takers for this one?
Thanks in advance.
