So I'm working in 2009 on a Vista x64 machine with 8gigs of RAM with a workshared file. There are only two people working in the file. Yesterday everything was working great. This morning, I open my local file, reload latest and STC to make sure that I get everything that was changed after I left last night. Now I can no longer open any sections in my file. I get this error "A serious error has occurred. It is strongly recommended that you use Save As to save your work in a new file before continuing." And my only options are to Save As and Continue or Continue Without Save. The other user can open sections without a problem. I tried Save As and it didn't change anything and my building section was totally empty. I tried Continue Without Save and the same thing happened. If I try to open a different type of section I get the same error, and with either option the section then opens just fine.
Any suggestions?
Thanks!
