I have two buildings I'm running through Ecotect room by room to check daylight levels.
Project 1 is "simple" boxes with punched openings. by simple I mean that they are mostly rectangular with some L shaped rooms and some rooms with alcoves, but all floor and ceilings are parallel, etc. I gave up exporting the model from Revit and simply redrew each zone in Ecotect. I used the zone tool to create what I thought were water proof boxes, placed windows which are hosted by the walls, etc. In one room I have a strange spike of light in one corner, far from any windows. I added a partition wall around that area so that there are NO ways for light to get in but it is still the brightest part of the analysis grid. I adjusted the grid to make sure that it was inset from the walls, same problem, it's as if the ceiling is missing for that area. Redrawing the ceiling didn't help, nor did putting a second ceiling as a shading object above the model. Obviously the results for that room are useless but I can't seam to identify what is causing the massive light leak.
In the second project I have the opposite issue. A rectangular room with a row of windows along one edge exported from Revit via gbXML. After running the daylight analysis I have one window (which started out identical to the rest) which doesn't have the typical bright spot in front of it. Again, how do I trust any result?
A. Is there a way to trouble shoot such issues.
B. Can I trust any results or should I use a different program... I'm talking about VERY basic analysis here.
edit: Second issue was user error, when the odd window was one which I used to check materials, and had inadvertently changed to no-material.
