Results 1 to 6 of 6
Thread: Default Title
    2015-12
    California
    33
    Default Default Title
    Is there a way to set the title a drafting view defaults to when dragged onto a sheet?
    Currently, mine defaults to No Title. It's truly annoying. =)
    2015-11
    standing @ the crossroads
    241
    Default Re: Default Title
    Did you rename the drafting view in the project browser? The title will match the name assigned to it in the project browser.
    2015-12
    California
    33
    Sorry, I phrased the question wrong...
    When you drag a drafting view onto a sheet, the default Viewport Title selected is 'No Title'. So, when you drag it on, there is no Viewport Title, just the detail.
    Is there anyway to change what Viewport Title it defaults to? For example, a 'Detail Title' or 'General Notes Title' that has the actual name and extension line shown, etc.
    Thanks for the reply, btw.
    2015-12
    California
    33
    No clue for anyone, huh?
    2004-06
    Memphis TN area
    7,048
    Only thing I've figured out to do is rename that No Title viewport type to the one you want to be default, and set it to the have the view title annotation you want. You may have to change all other viewports to something else first, then delete that one using Purge Unused, then change the No Title one to the one it should be. Then after you do all that you can make another viewport type to be No Title.
    2015-12
    California
    33
    Quote Originally Posted by patricks View Post
    Okay. Thanks for the tip! I appreciate it.
  1. Default Value for Prompted Entry in title block
    Last Post: 2013-02-21, 10:22 AM
  2. None default document title for Plot to PDFCreator?
    By Pwned555402908 in forum AutoLISP
    Last Post: 2012-04-03, 08:24 PM
  3. Viewport Title Default
    By Jrobker in forum Revit MEP - General
    Last Post: 2010-10-27, 11:45 PM
  4. View Title Default
    By kcarlson in forum Revit Architecture - General
    Last Post: 2010-04-08, 05:59 PM
  5. Setting default view title?
    Last Post: 2006-01-03, 07:14 PM
