If you open up materials and click on "physical" tab and select "wood" for the material type, you see design values from the Factory for Douglas Fir. Question #1, Can the physical parameters by modified? I want to add "tension parallel to grain" and a value associated with it.
Question #2, then I want to add different grades and species of lumber with design values from NDS. How?
Thanks
