Thread: Getting Closer
    I could stop if I wanted to Andy.88917's Avatar
    2005-06
    Midland, Texas
    230
    Default Getting Closer
    Here is my latest rendering using AutoCAD Architecture (with visionrez for roof and RPC for landscape). I am getting happier with my settings but still room for improvement.
    Thanks to neje for the suggestion on creating a structural memeber for my brick arches. I have done that and I think it's turned out pretty well for as simple as it is to add it to my model.
    Any comments or suggestions?
    2002-09
    Madison, WI
    5,688
    Default Re: Getting Closer
    Hi Andy,
    Not sure what the local customs are down there, but up our sidewalks are generally finished with a white sealer. Your sidewalks look like they were either just poured our you used a smooth finish on smooth concrete finish.
    My suggestion would be to try a brush finish and brighten up the color
    The house an general background look great, grass looks good, IMHO, it's just the sidewalk could use a little help.
    2002-12
    278
    Hey Andy that's looking great. Glad i could help. I think at times my suggestions are so 'down under' that they don't relate to how you do things up there. You are ahead of me!
    I like how the grass pops up above the path. I have to try that - I think I had trouble because slabs don't (didn't) render their sides, only top but I have been using spaces instead. It looks better with the different levels. I especially like your windows. My renders typically take about 1 or 2 mins (i'm impatient) but I think your glass would up that.
    Stone work looks great. Roof shingle maybe could use a little more bump.
    Should the entrance have a turn on it?
    I'll have to get those RPC's working.
    cheers
    2005-01
    94
    Thumbs up Re: Getting Closer
    Ohhhwheeee that is looking good Andy! Only thing, I am from Odessa / Midland so I am not sure if that "green" grass and trees are that realistic out there. Might need to add in some mesquite trees, lava rocks and tumbleweeds!
    Looking good my friend!
    Jay
  1. GS222-2: Autodesk LandXplorer Software Family: A Closer Look
    By Autodesk University in forum Planning and GIS
    Last Post: 2014-12-01, 03:34 AM
  2. DE401-3: Taking a Closer Look at the Autodesk Topobase API
    Last Post: 2013-05-05, 01:41 PM
  3. AR23-4L: A Closer Look at Walls in Autodesk(r) Architectural Desktop
    By Autodesk University in forum Building Design
    Last Post: 2013-03-30, 02:11 AM
  4. One sided wall closer.
    By AP23 in forum Revit Architecture - General
    Last Post: 2008-08-14, 06:48 PM
