Thread: Project Relocation / Shared Coordinates
    2009-07
    7
    Default Project Relocation / Shared Coordinates
    I am trying to relocate our structural model to line up with the linked in architectural model in Revit Structure 2010. When I select "Relocate Project", the model doesn't react or moves an asinine distance and I have to scroll around and find it. either way, the levels are still at the same height.
    I have done this several times before. I know I have to find a pull down menu somewhere and change the coordinates from "project" to "shared coordinates" but I don't remember where the menu is. can anyone shine some light on the location of this?
    2009-07
    7
    Default Re: Project Relocation / Shared Coordinates
    UPDATE: I finally found the menu. you have to select a level in an elevation view, edit type and then pull down to select shared coordinates. unfortunately, now the entire project disappears when i try to relocate, no matter what the distance is. any insight would be appreciated. thanks!
  1. Project Coordinates, Shared Coordinates, and the new Survey Point
    By Wes Macaulay in forum Revit - Platform
    Last Post: 2012-07-05, 06:20 PM
  2. Rotating a project with shared coordinates?
    By mickaeL_renauD in forum Revit Architecture - General
    Last Post: 2009-01-14, 05:59 PM
  3. True North/Project North and Shared Coordinates
    By tsong in forum Revit Architecture - General
    Last Post: 2008-04-03, 03:16 PM
  4. Replies: 0
    Last Post: 2007-09-30, 02:56 PM
  5. Project Level relocation
    By Joef in forum Revit Architecture - General
    Last Post: 2004-06-28, 10:40 PM
