Thread: Excel X,Y Coordinates --> AutoCAD
    2004-11
    3
    Question Excel X,Y Coordinates --> AutoCAD
    Does anyone know if there is a way to take a list of X,Y coordinates (approx. 300 or so) from an Excel file and put them into AutoCad 2002? Then connnect the points with lines to form a shape???
    any help would be great
    13,656
    Default Re: Excel X,Y Coordinates --> AutoCAD
    Hi
    Check out the following Technical Document on the Autodesk web site under the Knowledge Base section -
    ID: TS55797 - Importing coordinates from a Microsoft Excel spreadsheet with lines drawn between the points
    Have a good one, Mike
    2004-11
    3
    works perfect
    thanks
  1. Export coordinates to Excel
    By rputhenv in forum AutoCAD General
    Last Post: 2016-10-14, 02:09 PM
  2. Exporting the values of coordinates of Polyline/Line from Autocad to Excel
    By manolis_kakou391230 in forum VBA/COM Interop
    Last Post: 2013-12-05, 08:26 PM
  3. Replies: 5
    Last Post: 2013-10-16, 05:39 PM
  4. Civil 3D question - import points from excel, coordinates and attributes
    By Hotrod50 in forum AutoCAD Civil 3D - General
    Last Post: 2012-03-02, 05:09 PM
  5. Replies: 1
    Last Post: 2009-04-29, 11:03 AM
