Thread: Installing analytical line into a in-place framing family?
    2009-10
    25
    Default Installing analytical line into a in-place framing family?
    This kind of goes along with the "Attaching beams to model by face roofs - limitations?" that I posted.
    If I create a framing beam using a Model-In Place method (in order to place on a roof sloping in 2 directions), then one of the limitations that I come up against is the lack of a analytical line in the finished in place family.
    Of course this means that when I take my project out to anyalisis then it won't see that beam.
    Is it possible to install an analytical line into the family? The family was created using a Swept Blend, so maybe we can use the path line somehow?
    Using Revit Structure 2010
    Many thanks for any help.
    2007-08
    54
    Thumbs up Re: Installing analytical line into a in-place framing family?
    Yes, you should be able to add the analytical line while defining the in-place beam element. It will be a Analytical Model [Projection Line]. Create the solid shape, then before selecting to Finish Model (Green Check Box), choose the Model line Button from the In-Place Modeling Panel. Then use the Analytical Model [Project Line] Type to draw in your analytical line.
    Then Finish Model....Hope this helps you out!
    2009-10
    25
    Default Re: Installing analytical line into a in-place framing family?
    Brill, just done that and its worked a treat.
    Only limitation I can see is that I haven't got the Structural parameters in the Instance properties of the In-place beam.
    Do you know, or does anybody know if there is a way of putting in the Structural Analysis parameters, ie Analyse As and also the Structural parmaters like "Structural Usage"?
    Can those be inherited in some way?
    Many thanks.
  1. In-Place Structural Framing Family - Cut?
    By pwilson.112560 in forum Revit Architecture - General
    Last Post: 2015-08-19, 05:21 PM
  2. 2014: Framing Family Analytical Model
    By Ampersand in forum Revit Structure - General
    Last Post: 2013-11-26, 08:19 PM
  3. Replies: 0
    Last Post: 2008-11-11, 11:09 AM
  4. Replies: 2
    Last Post: 2006-12-18, 03:35 PM
  5. In-place structural framing family
    By Adam Mac in forum Revit Architecture - Families
    Last Post: 2005-03-23, 01:33 PM
