Thread: Schedule Voice & Data Connectors Seperately
    2008-03
    55
    Default Schedule Voice & Data Connectors Seperately
    Is it possible to schedule telephone and data connectors separately if they are part of the same family? The out of the box "Telephone - Data:plain" contains a voice & data connector. I would like to be able to schedule the data cabling to the data patch panel and the voice cabling to a telephone backboard.
    Thanks
    2009-02
    Houston
    686
    Default Re: Schedule Voice & Data Connectors Seperately
    Quote Originally Posted by Eddy B View Post
    Is it possible to schedule telephone and data connectors separately if they are part of the same family? The out of the box "Telephone - Datalain" contains a voice & data connector. I would like to be able to schedule the data cabling to the data patch panel and the voice cabling to a telephone backboard.
    Thanks
    First, you don't schedule connectors. You schedule families, or instances of families. So, in that sense, no you cannot schedule them separately. However, you can create two schedules, and simply show the fields in each schedule that to apply phone and data separately.
    Have I misunderstood the question?
    2016-01
    Garden Grove, CA
    344
    Add a shared parameter in the family so you can have 2 schedules and filter by that parameter.
    Revit MEP Moderator mjdanowski's Avatar
    2007-03
    890
    This might not be with your standard, but could you just schedule the locations of voice/data outlets, and then have a column for "Voice Cabling" and one for "Data Cabling"?
    Matthew Danowski, PE, LEED AP BD+C
    Project Electrical Engineer
    Baltimore, MD
    2003-06
    Manchester, NH
    222
    You might be able to accomplish what you are looking for by scheduling the circuit (system) rather than the connector.
    jason
  1. Copy schedule data from one revit schedule to another
    By ijnicholas in forum Revit - API
    Last Post: 2012-01-11, 10:35 AM
  2. 2011: Duct Connectors - drag to connect to other connectors
    By bb1 in forum Revit MEP - General
    Last Post: 2011-09-07, 07:56 PM
  3. Data / Voice Outlets Category
    By Batman in forum Revit Architecture - Families
    Last Post: 2010-03-10, 10:06 PM
  4. Export Design Options seperately
    By Andre Baros in forum Revit Architecture - General
    Last Post: 2006-01-03, 08:36 PM
  5. Export Design Options seperately
    By Andre Baros in forum Revit - Rendering
