Thread: Insertion point not moving when using move action
    2009-04
    Houston, TX
    204
    Default Insertion point not moving when using move action
    I set the insertion point on the top side at the midpoint, and I put in 3 move actions and included the entire block, attributes and all, in the selection set, yet the dark blue grip (indicating the insertion point of course) will not move, and I don't want a bunch of grips floating around in space. I tried just throwing a dynamic point on top of it hoping it might override and move, but of course the original insertion point grip stayed and the only the dynamic point moved. See attached block. Appreciate any assistance.
    I could stop if I wanted to msretenovic's Avatar
    2002-02
    Galloway, Oh
    305
    Wink Re: Insertion point not moving when using move action
    Insert a Basepoint parameter. If you include this with your Move Actions, your base point grip will move with your block.
    2009-04
    Houston, TX
    204
    Default Re: Insertion point not moving when using move action
    Worked like a charm, sadly I didn't think of it. Wish my instructors would've covered DB in the classroom!
  1. Move Block Insertion Point
    By ettore_c in forum AutoLISP
    Last Post: 2013-07-02, 05:12 PM
  2. Insertion point moving after using look up table
    By feargt in forum Dynamic Blocks - Technical
    Last Post: 2009-02-10, 02:30 PM
  3. Point parameter/move action
    By rstrandmark in forum Dynamic Blocks - Technical
    Last Post: 2007-11-15, 07:03 PM
  4. Make insertion point move with scale action
    By KRISTIVETTE in forum Dynamic Blocks - Technical
    Last Post: 2006-06-01, 07:03 PM
  5. Move block insertion point
    By kitter in forum AutoLISP
    Last Post: 2005-07-04, 07:38 PM
