Thread: MEP 2009 Using Multiple Cores
    2015-09
    481
    Default MEP 2009 Using Multiple Cores
    I usually work in RAC, but have started to use MEP 2009.
    I have noticed on several occasions now that revit will use a little bit of the second core (2% max so far)
    I have noticed this while open/close worksets and just now switching views. Is this typical? I know that RAC only uses more then one core when rendering, but will MEP use more then one for other stuff too?
    THanks
    Revit MEP Moderator mjdanowski's Avatar
    2007-03
    890
    Default Re: MEP 2009 Using Multiple Cores
    Its probably just a background process within Revit or Windows that every now and then has some activity.
    Matthew Danowski, PE, LEED AP BD+C
    Project Electrical Engineer
    Baltimore, MD
    2015-09
    481
    Ok, that is what i would guess. It's so sparatic and never goes above 2%.
    Thanks
  1. AutoCAD MEP 2014 & Multiple Cores
    By j.johnson in forum Its all in the Details
    Last Post: 2014-02-12, 03:32 AM
  2. Use of multiple cores Revit 2011
    By ParagonChris in forum Revit Architecture - General
    Last Post: 2010-08-12, 03:26 PM
  3. [2009] Multiple Cores (PENDING)
    By mjdanowski in forum Revit MEP - Wish List
    Last Post: 2010-04-26, 04:07 PM
  4. AutoCAD & Multiple CUP's and/or Multiple Cores??
    By stykface in forum AutoCAD General
    Last Post: 2009-11-23, 06:21 PM
  5. Replies: 2
    Last Post: 2007-01-15, 04:23 PM
