Thread: opening 2008 files in 2010 version
    Default opening 2008 files in 2010 version
    HI,
    i'm trying to open revit files from the 2008 version in the 2010 version, but each time it starts to upgrade the file and stop in the middle announcing Fatal Error.
    anyone has an idea why? what should i do?
    thanks!
    AUGI Addict truevis's Avatar
    2004-07
    Massachusetts, USA
    1,191
    Default Re: opening 2008 files in 2010 version
    Dunno; but try opening with Audit option.
    Also, turn off any links in the RVT in 2008, first.
    AUGI Addict DaveP's Avatar
    2002-12
    St Paul, MN
    1,569
    If you still have a valid license of 2008, open your project using the AUDIT option in 2008.
    Oftentimes the thing preventing an upgrade is an error that's been lurking in the project all along. Cleaning up the error BEFORE the upgrade will probably help.
    2003-04
    Chino, CA
    4,756
    Quote Originally Posted by revitalsaga View Post
    HI,
    thanks!
    contact your reseller to get support. They can either upgrade your file, or send it to Autodesk for upgrading. It sounds like you are running out of memory. Upgrading files from 2008 and earlier to 2009 and later is memory intensive due to the material upgrades for the change in rendering engines.
  1. Wrong Version Opening Files
    By jmoore284 in forum AutoCAD General
    Last Post: 2012-09-28, 08:03 PM
  2. opening solidworks 2010 files in inventor 2010?
    By chuck_cantieny in forum Inventor - General
    Last Post: 2009-12-19, 04:32 PM
  3. Windows XP - Autocad files opening in older version
    By CAD Brad in forum Operating Systems
    Last Post: 2008-08-01, 03:22 PM
  4. Replies: 2
    Last Post: 2007-06-12, 11:23 AM
