Results 1 to 6 of 6
Thread: Correcting off-axis section?
    2004-06
    94
    Default Correcting off-axis section?
    This has certainly been asked many times before- couldn´t find the threads though -
    I´ve got a section "slightly off axis" with lots of details drawn on it , so I wouldn´t like to make a new one. How do I correct the section angle to perpendicular in the most convinient way?
    2005-12
    566
    Default Re: Correcting off-axis section?
    Slightly off axis sections can be a pain. One solution: Draw a reference plane that you know is correctly angled, parallel to a wall for instance. Move the section so that one of the blue drag points is at the end of the reference plane. It should snap into place. Then, rotate the section about the snapped point. You may need to tab through a couple of possible points on the section in order to properly rotate it.
    2006-01
    Rotterdam
    84
    That is what I would do but I would like to ad::
    t might be easyer to rotate it way off in the wrong direction before rotating it into the right place.
    It would be nice if align would work on section lines.
    Geert
    2004-06
    94
    Thanks, I still didn´t succed in snapping the section on the referensline-end
    2004-06
    94
    Now ! the section tag has to be in one piece ie.there has to be no "gaps in segment"
    AUGI Addict DaveP's Avatar
    2002-12
    St Paul, MN
    1,569
    Dave Baldacchino had a thorough write-up of this a while ago. His issue was with Elevations, but this should work with Sections as well.
    http://forums.augi.com/showthread.ph...ning+elevation
  1. 'Section box' in {3D} view can be rotated about X or Y axis as well as Z axis.
    Last Post: 2012-02-06, 07:34 AM
  2. Correcting Lines which are slightly off the axis
    By harilalmn in forum VBA/COM Interop
    Last Post: 2009-02-05, 06:07 PM
  3. Correcting Cad Standards
    By rhayes.99001 in forum AutoCAD General
    Last Post: 2007-07-23, 02:29 PM
  4. Lines on X axis are drawn at varying Z axis
    By s.nail in forum AutoCAD 3D (2006 or below)
    Last Post: 2006-09-20, 04:23 AM
  5. Correcting Exploded Dims
    By zachgidich in forum AutoCAD General
    Last Post: 2004-10-04, 08:10 PM
