Results 1 to 10 of 11
Thread: How to make video's?
    2009-10
    15
    Default How to make video's?
    And by this i do not mean animating in what ever program. But the part after, the encoding part. I'm having problem creating video's of my animation that are high quality and easy to play back for my customers (if I can just give them an exe that they can install so they can play the video's it is fine by me) also file size is a concern too , preferred is a size under 10 mb so they can be mailed.
    I have been looking everywhere for concrete information for my problem but can't find it. Does anyone has any tips for me, or any direction to an information source where i can find the info (book or website).
    Greetings,
    Sander Obdeijn
    Design Visualization Moderator stusic's Avatar
    2004-10
    Denver, Colorado
    1,515
    Default Re: How to make video's?
    You'll need a video-editing program to create a video. Well, not exactly, but I'll explain.
    When I create an animation, I render each frame as an individual image (.tga, .jpg, whatever). I use a video-editing program (in my case, Adobe Premier) to compile all those images into a complete sequence. From there, I can specify what kind of compression, bitrate, etc. to use, including type of video (.avi, .mpg, .flv, .mov, etc.). The program will then render out the video based on the numbered stills I loaded. In most animation programs, you can render directly to a video file, but this reduces quality and gives no flexibility to make changes, etc.
    Does this help?
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Would you mind explaining your choice of Premier over after effects, combustion or toxic?
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2004-10
    Denver, Colorado
    1,515
    No real reason, I had used it at a previous job years ago and just kinda stuck with what I know. I would love for something that was more streamlined with Max, but I haven't found the time to look around.
    I think Autodesk may offer a solution in Combustion, but I don't know how well it handles video editing, encoding and authoring, which is my main concern, although I am interested in its interoperability with Max.
    It seems very similar to After Effects (which I occasionally use).
    I have heard of toxic, but I'm unfamiliar with it. Do you have a link?
    2015-12
    4,730
    Toxic was built from the ground up to take advantage of a 64bit OS. Its now bundled with Maya and no longer available for separate purchase - therefore I have no linky. Check out Maya 2010 Compositor for more info ( http://usa.autodesk.com/adsk/servlet...&siteID=123112 ). I don't know if a new version of Combustion has been released since its 2008 version.
    2009-10
    15
    Thank you very much I got a video. Just applied the windows media video 9 codec to the video since most people can play that i think and size and quality are ok.
    2007-08
    Denver, CO
    334
    Glad you were able to get it to work. Our workflow to a low file size animation starts with an image sequence that we create an uncompressed AVI from (either through After Effects, Combustion, or PDPlayer). That uncompressed file is saved for future compressions or video. To get the file down to a reasonable size, we use a little software called AVS Video Converter. It will convert any type of video to another (i.e. AVI to WMV or MOV) and gives you a variety of codec/compression options. I can get an uncompressed AVI to about 10% of it's original file size depending on the codec. Pretty slick stuff. There are other similar softwares out there tha will do the same thing.
    2004-10
    Denver, Colorado
    1,515
    The encoding of my animations is one of the hardest times I have; I can't seem to get the right balance of quality and filesize, while using a codec that all common players can play. PITA.
    2015-12
    4,730
    Quote Originally Posted by loydg View Post
    Interesting. Where do you source AVS Video Converter from? It seems like trouble for spam, identity theft or worse based on the google hits that came up when I searched it...
    2004-10
    Denver, Colorado
    1,515
    It's: http://www.avs4you.com/. And, yeah, it looks like a spam software site. Nifty program.
  1. 2013: some ways to make helix & spirals (tutorial video)
    By khw1016 in forum Revit Architecture - Tips & Tricks
    Last Post: 2013-07-11, 12:47 AM
  2. showing last frame of video when video has ended
    By sobdeijn in forum DV - The 3rd Dimension
    Last Post: 2009-11-09, 07:15 PM
  3. ATI video card... has Revit video settings!
    By Wes Macaulay in forum Revit - Hardware & Operating Systems
    Last Post: 2009-02-16, 07:03 PM
