We need (not just want) electrical conduit.
It needs to be not part of the piping/plumbing system. No workarounds, no 'just draw piping and "make" it show on the electrical plan.
It needs to physically connect to panelboards, main distribution panels, large motor starters, motor control centers, transformers, run above ceilings, on the site in manholes and hand holes, up above ceiling and through fire rated walls, incoming/underground with conduit sleeves, to generators, up through floors from electrical room to electrical room above, from communications room to communications room, connecting to junction boxes and pull boxes at every 270 degrees (3 turns).
EMT, (Electrical Metallic Tubing), IMC (Intermediate Metal Conduit), RMC Rigid Metal Conduit. LB Fittings (or connectors?), Conduits run underfloor from in-floor receptacle boxes, to name a few. How on earth can we expect to do an enlarged electrical substation room and NOT show the main building feeders? This is a major electrical item to exclude, especially for interference detection.
Just how does interference detection work properly if we are faking in plumbing runs and making them show? I think this item should be at the top of the MEP list electrically.
